Configuring SF300-24p and 7942G
Trubolex_
Hi, all!
The main reason why I'm open the topic - can't connect to switch, I don't know its IP and I can't find it, despite I'm connected directly to ethernet port. I tried to find IP by LanScope or WireShark. Also, I tried to connect by standart CISCO cable (DB-9?). I connected COM to switch's console-port and RJ45 to laptop, also, I tried use old PC with COM (COM to PC , RJ45 to Switch) and putty or HyperTerminal didn't see it.
Have any one ideas how I can connect to switch for managing?
7 Replies 7
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
I would suggest you to use the FindIT Network Discovery tool:
https://software.cisco.com/download/home/286311274/type/283453334/release/2.0.4
Please connect your PC directly to any of the switch ports. If the LED light on the port is showing activity, you will be able to find the current IP address using this tool.
Please rate this post or marked as answered to help other Cisco customers.
 Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Iliya Gatsev, thx for your reply.
This can helps if switch starts the first time, but for the already configured switch this is thingy doesn't work.
I'm NB in cisco, so I tried to find information about step by step configuring/connecting. And I'm failed. In all manuals, there is general information, like in mipopov's message.
But there is no information like this:
- Shutdown your switch
Set Putty to save everything in a file (skip if not needed):
- Session > Logging -- there, change None to Printable Output
- and choose folder with Browse
Set serial settings:
- Speed (baud): 115200
- Databits: 8
- Stop bits: 1
- Parity: None
- Flow control: None
Change Putty setting to accept Backspace:   Configuration > Terminal > Keyboard > Change sequences sent by: -> The Backspace Key -- there, change Control-? to Control-H
Check what number is assigned to COM port (if it is with native the port is always COM1):
You can save this configuration for later use or just hit Open.
- Open SSH session
- Connect Cable to com
- power on the switch (this is needed to see the boot process)
When it fully loads, login and issue the following commands"
If I'll connect cable after booting starts, I'll see the black screen without any signs of "life"
Для русскоязычных.
Либо я не сильно внимательно читал маны на английском, либо этот нюанс очевиден всем, в т.ч. и NB.
1) Выключите коммутатор,
2) Настройте параметры putty, согласно инструкции выше или инструкции из комплекта
3) Подключитесь кабелем с COM-портом(DB-9 абсолютно бесполезен, в данной ситуации, берите COM(м) - COM(м) и старый комп, с COM-портом, валяющийся в серверной. Как показала практика, один и тот же кабель может работать с cisco, но не работать с другими брендами и наоборот) к ПК и коммутатору.
4) Откройте сессию
5) Только сейчас включайте коммутатор
Sorry for Russian translation, but Russian techsup does not work at the weekend, English-language Cisco techsup routes me to the forum.
mipopov
Hello !
You need serial cable that comes with the switch (it is grey and it is null modem cable with DB9 female on both ends). If computer doesn’t have native COM port, you need also USB to serial adapter.
Download Putty -  link below:
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
- Databits: 8
- Stop bits: 1
- Parity: None
You can save this configuration for later use or just hit Open and power on the switch (this is needed to see the boot process)
When it fully loads, login and issue the following commands:
switchxxxxxx# show ip interface
and you will see the IP address/es
Cheers,
Mike
wycalero
Do you know the credentials of the switch? usarname and password?
@wycalero
Hi! Thanks for your reply.
As I said previously - I already connected to switch
Now I have new trouble - I didn't know credentials. Is there any opportunity to reset credential without wiping config?
Hello Trubolex_,
Reboot the switch by unplugging the power cord.
You will see a prompt during boot right after the Cisco logo made out of #s that says “Autoboot in 2 seconds – press RETURN or Esc. to abort and enter prom.”
You will see something similar:
Detected speed: 115200
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.3.5.06 Built  21-Jul-2013  15:12:10
Networking device with Marvell ARM CPU core. 128 MByte SDRAM.
I-Cache 16 KB. D-Cache 16 KB. L2 Cache 256 KB. Cache Enabled.
MAC Address   :  xx:xx:xx:xx:xx:xx.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Hit Enter and you will get the following startup menu:
    Startup Menu
[1]  Download Software
[2]  Erase Flash File
[3]  Password Recovery Procedure
[4]  Set Terminal Baud-Rate
[5]  Back
 Enter your choice or press 'ESC' to exit:
Select “Password Recovery Procedure” by typing 3, and then hit enter
“Current Password will be ignored” will be displayed.
==== Press Enter To Continue ====
Hit Enter
It will look like the switch is doing nothing, but don't worry just wait - it will boot. Once at the prompt you will need to elevate to privilege mode.
1. Switchxxxxxx>
2. Switchxxxxxx> enable
3. Switchxxxxxx#
If your switch has an existing configuration that you wish to keep (and only update the login credentials as in your case), first ensure to load the saved configuration into memory to update the existing user/password combination. This is a crucial step in gaining access back into your switch, otherwise you would essentially be performing a factory reset on the unit.
4. Switchxxxxxx# copy startup-config running-config
Enter the global configuration mode:
5. Switchxxxxxx# config
6. Switchxxxxxx(config)#
Create a new username and password combination (username can be whatever, password too so long as it meets complexity requirements)
7. Switchxxxxxx(config)# username cisco password your_new_password privilege 15
8. Switchxxxxxx(config)# exit
Save the password into the startup config
9. Switchxxxxxx# copy run start
That will set a new password in the running (and startup config) so that you will be able to access the switch after a reboot.
Enter the following command to reboot the system so that you can log in with your new username and password (verifying it will work in subsequent reboots):
10. Switchxxxxxx# reload
Once the switch powers up, login to verify.
Cheers,
Mike
Для русскоязычных.
Перезагрузите коммутатор, выдернув кабель питания.
Вы увидите возможность зайти в загрузочное меню сразу после Cisco лого: “Autoboot in 2 seconds – press RETURN or Esc. to abort and enter prom.”
Вот примерно как это выглядит:
Жмите Enter или ESC и попадете в загрузочное меню:
Startup Menu
[5]  Back
Выберите пункт [3] Password Recovery Procedure написав клавиатурой "3" и нажмите Enter
Вы увидите
Жмите Enter
Какое-то время будет выглядеть как будто коммутатор ничего не делает, не беспокойтесь - просто ждите пока загрузится. Когда увидите строку, надо будет повысить права.
1. Switchxxxxxx>
3. Switchxxxxxx#
Если вы хотите сохранить существующую конфигурацию (и только поменять пароль, как в вашем случае), тогда вам нужно загрузить существующую конфигурацию в память чтобы поменять пароль. это важно сделать иначе вы просто сделаете сброс на заводские настройки.
Поменайте на конфигурационный режим:
Создайте новое имя пользователя и пароль:
7. Switchxxxxxx(config)# username cisco password ваш_новый_пароль privilege 15
Сохраните изменения:
Таким образом вы поменяли/создали новый пароль run и в start и так сможете зайти после перезагрузки.
Введите команду чтобы перезагрузить коммутатор:
Когда коммутатор перезагрузится, попробуйте зайти с новым паролем.
