Console cable for SRW2048
stanleyhsuhung
I have lost the original console cable to the Cisco Linksys SRW2048 and was wondering if I can use the Cisco console cable or can a regular serial cable with female ends will work?
Stanley
chrebert
Level 4
Level 4
Hello Stanley,
A cisco console cable probably won't work since they usually have RJ-45 on one end.  However, a regular serial cable should work just fine, as long as your computer has one as well, or you have a USB to serial adapter.
The settings for the console port are as follows:
Bits per second: 38,400
Data bits: 8
Parity: None
Stop bits: 1
Flow control: None
Once you open the connection you'll have to hit enter once to make anything display.
You can also acces the console of this switch through telnet, by connecting to the switches IP with a telnet client and use admin as the username with a blank password.
I got most of this info from the admin guide, which is available here:
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administration/guide/SRW-US_v10_UG_A-Web.pdf
Let me know if that works,
Christopher Ebert
Network Support Engineer - Cisco Small Business Support Center
chrebert
Level 4
Level 4
Hello Stanley,
Data bits: 8
Parity: None
Stop bits: 1
Flow control: None
Christopher Ebert
Thanks! All good now!
For those who need a connection cable !!! I have a Prolific USB-to-Serial Comm Port, I connected 4, 3, 1 pins on my cable and the same pins on the switch, and everything is ready, after we connect via the hyperterminal: 38400-8 -no-1-no, "ENTER", enter the administrator password, the default username is "admin" and the password is "admin".
The 1: 1 connection works perfectly. You just have a mistake in pin numbering. These are correctly pins 2,3,5. The pin numbering display is shown in the figure.
https://photos.app.goo.gl/oew8jcKmaWWvGjMm9
