Create vlan and conf access-port
andre.ortega
I need create 2 vlans (vlan 10 and vlan 30) in Cisco  300 Series Switch.
VLAN 10 need be default VLAN (no tag).
After I wish associate port 1 to VLAN10 and port 2 to VLAN 30. The two ports must be access.
Can anyone give a step-by-step for this??
Best Regards.
David Hornstein
Level 7
Level 7
Hi Andre,
Made a fiour minute video to show you how to create two vlans and I believe answer your question.
After you make the changes,  i have suggested, be sure to save the configuration within the switch.
( the audio died whilst i was starting to save the running config to the startup configuration )
Also , it isn't indicated clearly, but in the "port to VLAN" page make sure you select go after you select a VLAN to modify. See the encircled go button in the screen shot below.
Click here to see the 4 minute video  or the link below;
https://ciscosales.webex.com/ciscosales/ldr.php?AT=pb&SP=MC&rID=51454237&rKey=4f26434b104275a8
regards Dave
David Hornstein
Level 7
Level 7
Hi Andre,
regards Dave
Really Thanks David. Very good the vídeo.
In my config VLAN 10 is default VLAN. This make any change in configurantion of the ports?
One more time thanks.
