Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2803 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4342 Views
  • 1 replies
  • 16 Helpful votes
I am face with an issue where I cold not add a port to a dynamic vlan.The specific error is :Dynamic VLAN cannot be modified.The error log is below:Error codes from RAM2147483422 2010-Apr-28 14:37:06 Informational %VLAN-I-GVRPDelVlan: Dynamic VLAN V...
Hi AllI am trying to work out how to route between 7 vlans i have setup on my sg-300 in layer 3. when i look at the ip4 static routes i see that the managment vlan is listed as local but there are no other local interfaces. this is confusing me some ...
I have an slm2005 (amount other slm boxes) that has broken yet again.  It seems to boot and then all the lights flash but anything I plug into it won't light the associated port LED and I can't access the admin web page.  Where can I find out if it's...
wdaher000 by Level 1
  • 596 Views
  • 1 replies
I'm looking for some assistance/guidance for IP helper configuration on a SF 302-08P. Currently, we are connecting a 302 to a Cisco 4507R-E chassis. Our VLANs are correctly configured on each switch (VLAN 1 for data, 2 for voice, 3 for management) an...
greggs123 by Level 1
  • 1108 Views
  • 1 replies
I'm trying to set up port descriptions on a 5 switch stack of 48 port SGE2010P switches.  Doing this through the Web GUI isexcruciatingly slow.  I tried doing it at the CLI with the 'desc' command, and that seems to work (if I do a show run the descr...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
