Credentialed Scans for CBS220
chughes03
I have an offline system that hat the CBS220 24 port switch.  I have ssh enabled and password authentication enabled.  The account credentials are supplied in Nessus.  The Nessus scan states no for credentialed scan but have a separate plugin that states it was able to login into the host with the supplied credentials.  The account being used is a level 15 account, I have also tried a user account with enable password and still receive the same errors.  Looking for help to get the scan to state credentialed.
Edit:  I am able to login using ssh through the cmd prompt and PuTTY.
Thank you
Clint
pieterh
looks to me more like a question on Nessus than a CBS220
but it could mean is cannot do a snmpv3 authenticated scan
do you find anything in the CBS220 logging regarding the failed authentication ?
furthermore
>>> The Nessus scan states no for credentialed scan but have a separate plugin that states it was able to login into the host with the supplied credentials <<<
     Tenable Nessus Credentialed Checks (Tenable Nessus 10.6)
     You can detect if your credentials are not working using plugin 21745.
     When a login is successful, this plugin does not produce a result.
=> this is contradictory with your information that a successful login is logged ???
luygi80
chughes03, I'm having the same issue with the same switch. Were you able to find a solution? Thanks in advance.
