Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2608 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4140 Views
  • 1 replies
  • 16 Helpful votes
hi, i have a priblem in connecting antminers only 4 come online and if i remove this 4 then the other 4 online and i take new ips of 1 gbps then i connect more 4 and i have 50 pic and i want to connect to 1 isp can u suggest any option or metherd
uddin9101 by Level 1
  • 811 Views
  • 4 replies
Hello, I realize this is a forever ago question but I am needing some current confirmation on this switch before I build my network out.  So this switch has four 10-gigabit uplink ports - XG1 thru XG4.  Can I use XG4 to uplink to the router/firewall ...
EvanC75 by Level 1
  • 740 Views
  • 2 replies
Hi there. I'd like to know if there's a command I can run to turn off paging on my SF302 switch. So for example, when I run the "show logging" command on the CLI, I'd like to it return all the results instead of prompting me to hit space bar or enter...
juleedev by Level 1
  • 51835 Views
  • 9 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
