Difference between SG200 and SG250
smillee3134
Please tell me the difference between 200 and 250 series eg. features or ways to configuration. Anyway I'm aware that some of 200 series has been list on EOL and replaced with 250.
Seb Rupik
Hi there,
Having read the data sheets, the SG250 has more RAM, larger flash and supports HTTPS (!!) management. All other attributes, switching performance, feature set and even weight (in some cases) is the same.
As you say the SG200 has recently been EOL'd so in the interest of ongoing support you money is better spent on the newer SG250 line.
cheers,
Seb.
What's about Layer 3 routing?
In datasheet  of Cisco 250 series have: Layer 3 routing, IPv4 routing(Up to 32 static routes and up to 16 IP interfaces), Layer 3 interface, ....
In Cisco 200 series have no ......
Trần Quốc Hưng - Technical Support - www.techmartket.vn
