disabling i2c error when operating the sf300-24pp switch
ye-pavlenko
disabling i2c error when operating the sf300-24pp switch. I want to run it without the poe board that burned out
@ye-pavlenko hi, this error comes when PoE is dead on board so its related to hardware. still you can use for non PoE connections.
try below in config mode
1. #no logging console
2. #no logging class session console informational
in show run output check if there is any additional logging like this. and try to disable logging related to console. but sometimes this may not work as this error is related to hardware.
Good luck
KB
ye-pavlenko
The same switches are also available without poe. I don't think the motherboard will change radically, I think there is some possibility, rather software-wise, to disable the polling of the poe board. I don't think anything needs to be physically soldered.
I really need a switch without poe, that's why I'm messing around with this.
