EAP modes are supported by RADIUS server built into the SG350/CBS350
towcz
Which EAP modes are supported by RADIUS server built into the SG350 or CBS350 switch? Can not find such information in product specification or data sheets.
Martin Aleksandrov
The CBS350 built in RADIUS server supports local EAP mode which is EAP MD5.
So for PEAP-MSCHAPv2 authentication (802.1x) I must use an external server?
That is correct.
jingo
got the same Problem and its absolut ridicoulus. The embedded Server does not support modern algorithms. Even the built in client denies such request from its own embedded server. I want to use those in conjunction, so please fix it.
When I look at the packets in wireshark there is even a hint not to use eap md5 because its prone to mitm-attacks...
So please, fix it :).
Best,
jingo
