ESW-520-8P-K9 POE Capabilities
ty
Can the ESW-520-8P-K9 supply enough POE to support 7 PVC2300 cameras?  If not, what are it's limitations?
Albert Wilhelm
The ESW 520 8-port has a maximum power of 15.4W to any 10/100 port; 60W total.
The ESW 540 8-port has a maximum power of 15.4W to any 10/100/1000 port; 123W total.
Per the PVC2300 datasheet, each camera has a power consumption of 10W.
If you need all 7 cameras supported, you might want to consider the ESW540 8-port. Another option is to power the cameras via the external power adapter, assuming a power source is nearby.
Hope this helps.
Bert Wilhelm
APW Solutions
Austin, TX
Albert Wilhelm
Hope this helps.
Bert Wilhelm
APW Solutions
Austin, TX
Definitely helps!  Thanks for the detailed answer.
Steven DiStefano
We produced a nice POE calculator you can use yourself/  Posted in hee too.
Teach a man to fish :-)
https://supportforums.cisco.com/docs/DOC-10495
Steve
