ESW 520 IGMP Snooping
hakim.benayed
Hi all,
I have to deploy a full IP-TV solution and the IGMP snooping must be supported on the switch.
I know the the ESW 520 support this protocol but the full IP-TV solution will manage uo to 200 set up boxes, does this switch support all this traffic?
I also have another question, what exactly mean
"Combo SFP slots include one 10/100/1000BASE-T Ethernet port and 1 SFP-based Gigabit Ethernet slot for fiber, 1 port active at a time." ? Is when I use 1 port with LX sfp transcever the 3 other uplink ports will be inactive and I can't add another or trunk it with another switch?
Thx for the support.
BR
hakim.benayed
Please an answer!
Hello Hakim,
I cannot answer your first question. I think that if you provide some more detail, such as how much traffic 200 "set up boxes" will generate, you may have a better chance of a response.
Regarding your second question, you can have two trunks using EITHER the two 10/100/1000BASE-T Ethernet ports OR the SFP-based Gigabit Ethernet slots for fiber OR one of each. Of the four ports you can only use two at a time because they are "shared".
