Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3572 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5255 Views
  • 1 replies
  • 16 Helpful votes
Hi My name is Chris and I’ve recently brought a SG 300-52 for my company with the main intention of using the L3 switching, I’ve recently gone on a 3day cisco course and came backing thinking i knew what i had to do but as always if you don’t have ...
cope.chris by Level 1
  • 10256 Views
  • 26 replies
Hi,Question. For Auto Voice VLAN (withouth Telephony OUI) to work properly; do you need to configure the Smartport Type Settings? To be more specific, when you look at the IP Phone and IP Phone + Desktop smartport type (macro); do you need to change ...
HI allI setup SRW2024 a long time, but after I restart it ( plug out and plug in pwoer core),it can not access in Web page,I don't know what happen why.But I try to use serial port cable to connect it, also can not access in HyperTerminal. if cable i...
eric by Level 1
  • 10575 Views
  • 5 replies
Hi all, i have allready read a lot of information, but steal don't know ther answer, please help DHCP server is allocated on 2911 router (c2900-universalk9-mz.SPA.152-1.T.bin)on SF300 (l3 mode):interface vlan 8 - 192.168.8.2/24interface vlan 18 - 192...
On an SG300 switch, is it possible to port mirror the ports that make up a LAG?  When I try to do that, it displays a port mirroring status of "Not Ready" for the ports.Also, is it normal for the switch to stop accepting traffic on the destination po...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
