esw-540-48 - direclty connected to port 34, still no MAC in ARP table
fircosoft1
Hi all,
I have a ESW-540-48 with firmware 2.1.21 (latest)
I have the strangest problem: I can 't find the MAC address of a computer plugged directly on the switch in the ARP table.
I'm trying to search by MAC address, and also by port .
If I reboot the switch, it does work as expected.
Do you think it is software related, and in this case is there anything planned to solve this problem ?
Or maybe I should just replace my hardware ?
Tom Watts
Hi Firco, it may be possible it is a smart port issue. The ESW switches are very particular to use the correct smart port roles for the connecting devices. I don't think a hardware replacement is warranted unless the given ports absolutely failed to forward.
As a secondary thought, it could also be a spanning tree issue. Ensure you're using RSTP and/or the host ports have port fast enabled. If using classic spanning tree it takes nearly a minute for a port to go to forwarding state. You can disable spanning tree on the port for testing to quickly rule that out.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
