Ether-channel with trunking in SRW2024
marc.rivero
I'm trying to configure a Ether-channel between SRW2024 and a cisco Catalyst 4507 to be a trunk, and let to traverse the trunk one tagged vlan (504) and one untagged vlan (1). I can configure the trunk (without ether-channel) and it works perfectly. But, the problem is when I try to configure a Ether-channel to use one port that is in trunk mode. When I try to attach this port, I get the error: The port g12 belongs to a vlan. The port and LAG configuration is the same (both with trunking and one vlan tagged and the other untagged). How I need to configure the port that I'm going to attach to EtherChannel? In access mode? But, If I configure the port in access mode, it won't work tagging vlans although the LAG port is configured with trunking, isn't?
Thank you in advance for your help. I couldn't know how to contact LinkSys to make a service request because although Linksys is now part of Cisco, I cannot open a service request at Cisco home Page.
Best Regards,
Marc Rivero.
0 Replies 0
