FATAL ERROR on SG300
cisco.com
We have several SG300 Series Switches (8, 20, 28 and 52-Port Versions) running. All Switches do reboot from time to time: Some after a week or so, others several times a day and then run again happily. In the log I see:
%SYSLOG-F-OSFATAL:
FATAL ERROR: tExcTask: ABORT DATA exception
***** FATAL ERROR *****
SW Version: 1.2.7.76
Version Date: 19-Jul-2012 Version
Time: 17:54:43
Instruction 0x2C
Exception vector 0x10
Program state register 0x80000092
***** END OF FATAL ERROR *****
This happens with FW Version 1.2.7.76 as well as under Version 1.1.1.8.
I do not know if this is related to FUGU, but it usually happens, when I try to open a connection with FUGU to some other host in the network. Where can I get help on this? I cannot find a place to report bugs to cisco. Thanx for your help.
Regards, Adrian.
10 Replies 10
cisco.com
Hi Adrian, can you post the entire flash memory log error?
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
2147469364     2012-Oct-10 01:20:50    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.2.7.76 Version Date:  19-Jul-2012 Version  Time:  17:54:43 Instruction            0x2C Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147470191     2012-Oct-01 19:39:52    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0x2C Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147471024     2012-Sep-18 20:12:29    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147471857     2012-Sep-18 20:04:58    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147472690     2012-Sep-18 19:39:40    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147473523     2012-Sep-18 18:10:22    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147474356     2012-Sep-18 17:56:19    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147475189     2012-Sep-18 17:52:42    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147476022     2012-Sep-08 12:55:29    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147476855     2012-Sep-07 02:41:45    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147477688     2012-Sep-07 01:58:15    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147478521     2012-Sep-07 00:59:42    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147479354     2012-Sep-06 23:09:19    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
2147480187     2012-Sep-06 23:01:15    Emergency     %SYSLOG-F-OSFATAL:   FATAL ERROR: tExcTask: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.1.1.8 Version Date:  30-Aug-2011 Version  Time:  10:46:34 Instruction            0xFF1B6D44 Exception vector       0x10 Program state register 0x80000092 ***** END OF FATAL ERROR *****
I pasted all flash log entries back to Sep, 6th.
Thank you for looking at this.
Regards, Adrian.
Adrian, thank you. These error messages are separate than the other topic. So I think it is a different problem although the register error is the same number which likely means it is the same resolution.
If you really want to persue this, we need a whole lot of data. I will notify the L2 team and the development team of your post and see if there is something we can do for you.
-Tom
Hi Tom
Since I'm doing nothing really very special with these Switches I think, I'm not the only one concerned on this planet. I can't do the testing for cisco since I do not have a spare Switch, but I can provide all data needed including the config. Just tell me by email, what information you need to open a case. Do you use GPG?
Thanks for your help.
Regards, Adrian.
Hi Adrian, as promised, I have reached out to the development team. Can you please provide the following;
1) config file (for each affected switch)
2) NW diagram (network topology)
3) Full RAM and flash file
4) Does issue happen only on 1 switch or on a few. If on a few switches – do they reboot at the same time
5) Information on devices connected to switch and protocol running on network.
6) From log file on case I can see that Sep 6-8 there are quite a few reboots. Then no reboots until Sep 18th. On sep 18th there are again many reboots (around 6) – and then no reboots until Oct 1st.  Can customer check if this correlates with any activity in his NW for  these dates (was there a specific device or protocol connected on the  “rebooting” days and not on others?
Can customer elaborate on the FUGU usage or send packet capture?
Also, I do have a special debug command for you (I will not post this publically). Please send me an email all of this information. Once I receive all this information, I will provide a special debug command we can run before the switch error to help isolate the incidents.
Thank you.
-Tom
I sent you the infos by mail.
Adrian, I have forwarded your information to the development and L2 team. Additionally, I've emailed you a detailed debug instruction. Please perform this and collect the data.
-Tom
bbp5401ag
I am seeing a similar issue - is there a fix for this yet?
SG300SW04#show logging file
Logging is enabled.
Console Logging: Level info. Console Messages: 2 Dropped.
Buffer Logging: Level info. Buffer Messages: 44 Logged, 42 Displayed, 1000 Max.
File Logging: Level error. File Messages: 192 Logged, 46 Dropped.
4 messages were not logged
Application filtering control
Application                 Event                       Status
AAA                         Login                       Enabled
File system                 Copy                        Enabled
File system                 Delete-Rename               Enabled
Management ACL              Deny                        Enabled
Aggregation: Enabled
Aggregation aging time: 300 Sec
26-Mar-2013 15:02:14 :%SYSLOG-F-OSFATAL:
SW Version  :  1.2.9.44
Version Date:  30-Sep-2012
Version Time:  01:33:07
Instruction            0xFF90FFE0
26-Mar-2013 14:38:08 :%SYSLOG-F-OSFATAL:
26-Mar-2013 14:34:08 :%SYSLOG-F-OSFATAL:
26-Mar-2013 14:09:41 :%SYSLOG-F-OSFATAL:
Hi bbp
Cisco Support wrote me:
On 11/30/12 1:57 AM, Marcelo Demello wrote:
> Hello Adrian,
> Unfortunately, I have now way to track the release date with the case
> closed. I think we should have a new code coming in the next 2 months, the
> 1.3.xxxx, that will include the fix.
> Thank you,
> Marcelo
So just check the Firmware Update Page of sg300. Or to work around: Switch off bonjour on your switches.
Regards, Adrian.
