05-08-2012 06:34 AM
i want to download an backup of the configuration file of my Cisco sg300-10 but do not know what to call the file extension.. backup.??? backup.img? backup.ros ?
thanks !
Solved! Go to Solution.
05-08-2012 09:34 AM
You will go to Administration > File Management > Download/Backup Configuration. From there you select Backup and then hit save. It will prompt you to save the file.
05-08-2012 08:07 AM
Hello Andrea,
The configuration file for the Sx300 series is saved as a text file (.txt). You can open the to both view and modify the configuration.
05-08-2012 09:00 AM
mmm i dont' understand, i want to backup the configuration on my pc... what is the proper procedure from http?
thanks
05-08-2012 09:34 AM
05-09-2012 12:12 AM
Thanks!!
