Firmware bug: SF220 "switchport protected" command missing
vitaliy.isarev
Hello!
We have SF220-48 switches and there are no "switchport protected" command:
sw-u1(config)#interface fa1
sw-u1(config-if)#switchport
  access         VLAN unaware port
  default-vlan   default vlan
  dot1q-tunnel   802.1Q tunnel port
  forbidden      forbidden
  general        Configure switchport in general mode
  mode           port mode
  port-security  Configure an interface to be a secure port
  trunk          VLAN aware port
  vlan           VLAN
sw-u1(config-if)#
But show interfaces protected-ports command available.
shawn.walsh
I have the SG220-26 switch and am also finding that the switchport protected command is not available. Did you ever manage to find a workaround for the isolating of the ports without the availability of this command.
Shawn Walsh
The SF220 does not have this command despite reading the online documentation suggesting it should do
