firmware upgrade failed on linksys-cisco WRV210 router
bazistanar
After a Linksys-Cisco WRV210 firmware upgrade I can't reach the configuration surface by any browsers. I can ping the 192.168.1.1 address successfully, but a can't configure the router. I tried the to use the reset bottom without any success.
Thank's for suggestions to solve the problem.
Zoltan Kocsis
Philip D'Ath
Have you tried both http and https?
I assume you don't have a proxy server configured in your browser.
Yes, I'v tried both, and no proxy server.
I'm almost sure, that the firmware upgrade has failed. The question is: is there any possibilities to perform the firmware upgrade, without using the built in configuration software of the router?
