Firmware upgrade SG200-26P progression
GQuack
Greetings, I am way behind with upgrades to my SG200-26P switch and need to get current, I am running 1.3.0.62. I've read several posts about skipping intermediate versions and want to confirm the correct path so I don't cause issues.
Looks like I next need to upgrade both boot and firmware to either 1.3.5.58 or 1.3.7.18.
After that I'm not quite sure but thinking I need to upgrade to each version where there is new boot code, is that correct?
If that is correct, after my previous upgrade, I would go next to 1.4.1.03 (boot and firmware) and then I can perhaps go directly to 1.4.8.06?
Appreciate all the help and support in advance, thank you.
Seb Rupik
Hi there,
For any boot loader version lower than 1.3.5 you need to upgrade to 1.3.5.58 . From there you can jump to the latest firmware version (1.4.8.06).
I've detailed the process here:
https://configif.wordpress.com/2017/08/03/cisco-200-300-and-500-series-pre-v1-3-5-upgrade-procedure-via-cli/
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
Seb, your info was spot on, thank you. Upgrade has been successful and now running boot version 1.3.5.06 and firmware version 1.4.8.6. Thank you!
So where do we get Boot Version  1.3.5.58 ? I can find the Firmware, but not the boot file.
Hi there,
On the download page:
https://software.cisco.com/download/release.html?mdfid=283019611&softwareid=282463181&release=1.4.8.06&relind=AVAILABLE&rellifecycle=&reltype=latest
...using the software version tree structure on the left, go to 'All releases -> 1 -> 1.3.5.58 ->  Sx300 Firmware Version 1.3.5.58
The zip file will contain sx300_boot-13506.rfb
cheers,
Seb.
