Console connection prompt with no options
ScottBris
New environment running 6 x SG500s stacked. I can connect with SSH and GUI, but when I try to connect via the console all I get is a “>” prompt and there’s only two options, debug and help:
>en
Unknown parameter
May be one from the following list:
debug             help
I've tried different speeds, anything other than 115200 and 9600 doesn’t connect, tried different cables/laptops etc. I get the feeling it could be permission issue but that looks straight forward. There isn’t a “no exec” in the run/start-config.
Interestingly if I set the speed using “line console, speed 115200” it updates the run-config, but “show line console” command still outputs "autobaud" which is set in the GUI. Have also set static speed 115200 in the GUI everything lines up and still get the same issue.
Any ideas?? I’m stumped.
Cheers,
Scott
SW1#show line console
Console configuration:
Interactive timeout:  10 minute(s)
History:  10
Baudrate: 115200
Databits: 8
Parity: none
Stopbits: 1
SW1#
SW1#
SW1#show authentication methods
Login Authentication Method Lists
Default             : Local
Enable  Authentication Method Lists
Default             : Enable
Line           Login Method List         Enable Method List
Console        Default                   Default
Telnet         Default                   Default
SSH            Default                   Default
http                : Local
https               : Local
dot1x               : Radius
SW1#
SW1#
raluani
My name is Rozana and I am an engineer from the small business team.
Could you please tell me on which of all 6 units you try to connect to via Console?
By design, once they are in a stack, you can connect only to the stack master.
Regards.
raluani
Regards.
Hi Rozana,
Thank you for your reply, that was a great point - it looks like our master has failed over recently without me realising. I can console to the new master, just about to move it back to where it should be.
Cheers,
Scott
