GVRP not propagating between SG300 and SG550
MarcusG
I have some SG300 and SG550 switches trunked together. GVRP is enabled globally and on each truck port on all switches. GVRP is working between the SG300 switches, but not to the SG550 switch. Any idea why that could be?
On a separate note, when I go to the GVRP statistics page and click "show all ports" button on the bottom, it says 0 for everything. Although when I view statistics for an individual port it shows non-zero data. This does not seem intuitive.
Marcus
mipopov
Hello Markus,
Happy New 2019 Year!
Is GVRP enabled on SG550?
To check issue the command:
switchxxxxxx# show gvrp configuration
What is the switchport mode on SG550 links - access or trunk ?
For example lets say you have uplink gi1/0/1 - issue the command:
switchxxxxxx# show run int gi1/0/1
Cheers,
Mike
