Help to find the right product
aneta.deliu1
Please I need to find the right switch, with the following specifications:
Managed 8-Port Gigabit SFP Standalone L3 Switch with 4 Combo 1000BASE-T Ports, IPv6
Packet Buffer
2MB
MAC address Table
16K
IP Routing
256 Static/ 12k Dynamic Total
Aggregated Bandwidth
24Gbps
Throughput
17.86Mpps
Transmission Method
Store-and-Forward
Forwarding Rate
14,880pps (10M)
148,800pps (100M)
1,488,000pps (1000M)
VLANs
Support up to 4K Static, 255 Dynamic 802.1p VLAN Groups
Priority Queues 8 Queues - Strict Priority or Weight Round Robin Queue Scheduling
Classification ACLs
Switch Port, VLAN ID, IEEE802.1p, MAC Address, DSCP, Protocol Type, IPv6 Traffic Class, IPv6 Flow Label, TCP/UDP Port, User Defined Packet Content, Time Based ACL, CPU Interface Filtering
Classification QoS
Switch Port, VLAN ID, IEEE802.1p Priority, MAC Address, IP Address, DSCP, Protocol Type, IPv6 Traffic Class, IPv6 Flow Label, TCP/UDP Port, User Defined Packet Content
Multicast Support
IGMP v1/2/3, IGMP Snooping, MLD Snooping (1K Groups)
Jumbo Frames
Up to 9216Bytes
Interface Options
RJ-45
10BASE-T, 100BASE-TX & 1000BASE-T
LC
With Standard Small Form-factor Pluggable (SFP) Gigabit Transceivers
RPS
Redundant Power Option Via Optional DPS-500
Network Management
In Band & Out of Band
Telnet, CLI/Console, RMON, Web-based HTTP, SNMPv1/v2/v3, Syslog, Port Mirroring, TFTP Client, BootP Client, DHCP Client, BootP/DHCP Client
IEEE
802.3 Ethernet, 802.3u Fast Ethernet, 802.3ab Gigabit Ethernet, 802.3z Gigabit Ethernet, 802.1d Spanning Tree, 802.1w Rapid Spanning Tree, 802.1p Priority Tags, 802.1q VLANs (4K static/255 dynamic), 802.3ad Link Aggregation (32 Groups/8 ports), 802.3x Flow Control, 802.1x Port-based/MAC-based Authentication, 802.1s (Multiple Spanning Tree)
IETF
RFC 1157 SNMP, RFC 1112/2236 IGMPv1/2 IGMPv3, RFC 1757/2021/2819 RMON (4 Groups), RFC 1493 Bridge MIB, RFC 1213 MIB II, RFC 793 TCP, RFC 826 ARP, RFC 854 Telnet, and DiffServ, RFC 1724 RIP v1/2, RFC 1850 OSPF,DVMRP, RFC 2934 PIM DM, PIM-SM, RFC 2932 Multicast Routing, RFC 2787 VRRP, RFC 2096 IP Forwarding Table MIB (CIDR), RFC 2787 VRRP MIB, RFC 2618/2620 RADIUS Accounting Client, RFC2618 RADIUS Authentication Client MIB, RFC 2863 IF MI B, RFC 2674 802.1p MIB, RFC 2668 802.3 MAU MIB, RFC 2665 Ether-like MIB, SSH2, SSLv3, TACACS+
Electrical & Emissions Summary
Emissions
CE class A, FCC Class A, VCCI Class A, C-Tick Class A
Power Supply
AC Input: 100 - 240 VAC, 50/60 Hz Internal Universal Power Supply
Power Consumption
60 Watts (maximum)
Heat Dissipation
187.67 BTU/Hr
Power Consumption
Compliant
Safety Agency Certifications and Environmental
Safety
CSA International, CB Report
Temperature
Operating: 0° to 40° C (32° to 104° F)
Storage: -40° to 70° C (-40° to 158° F)
Humidity
Operating: 10% to 85% RH, Non-condensing
Storage: 5% to 95% RH, Non-condensing
Philip D'Ath
There is a 12 port SFP Cisco 3850 that exceeds most of those specifications by quite a bit.  You'll need to use 1000BaseT SFP's to get copper into it.
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
Philip D'Ath
Note to get full OSPF you'll need the "IP Services"/Enterprise model.
WS-C3850-12S-E
Sunil Soni
