How can I analyse stream on SF302-08P
I have a switch SF302-08P and I am looking for an option to analyse all stream on it. I tried to enable netflow but it seems the product does not support it, because I cannot have access to ip flow like here : http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/netflow/configuration/12-4t/nf-12-4t-book/cfg-nflow-data-expt.html
Here are informations about switch :
switch08G4#show version
SW version    1.3.5.58 ( date  10-Oct-2013 time  17:15:41 )
Boot version    1.0.0.4 ( date  08-Apr-2010 time  16:37:57 )
HW version    V30
switch08G4#configure terminal
switch08G4(config)#interface range FE 1-8
switch08G4(config-if-range)#ip
  arp                  ARP configuration commands
  dhcp                 Configure DHCP services
  source-guard         Set the IP Source Guard enable status on the interface
switch08G4(config-if-range)#ip flow ingress
% Unrecognized command
Thank you for your answer
Tom Watts
Hi Emmanuel, this product does not support anything like Netflow. Your closest bet is SNMP and that probably wouldn't do what you want if you're specifically looking for the feature sets of Netflow.
One thing I have a question, when you say "analyze all stream", does this mean you want to capture all traffic so you can save it and review it? The closest you can do with that is make a monitor session for a whole VLAN and throw wireshark on there to capture the data. I'm not sure this is what you'd want but if you want to capture all packets and save it somewhere, that is a way to do it, albeit a bad way to do it.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
Thank you for your answer. I don't know yet the solution I will use, but I want to find users who consume the whole bandwidth in my company. I thank about using Netflow, but now, I think I will use Wireshark.
