How do I access the web utility with model cisco sf302-08p ?
abdiel.pema
Hi,i have a problem with the model Cisco SB SF302-08PP Switch , i connect a cable rj45 to my pc and configure the adapter local area connection (ip address:192.168.1.252), the LEDs blink green, and go to the address bar and get the IP by default, which according to the manual is 192.168.1.254 and the result is: page not found. Is there any way to change the web utility? How do I access the web utility?
nijamudeen_aziz
restore  the switch by holding more than 30 seconds and try accessing with ip 192.168.1.254. username and password is "cisco". before change your base ip to 192.168.1.2-253.try to ping and check the connectivity
Take a paper clip,hold the reset button for 30 seconds then try to access the web interface. It will work.
nijamudeen_aziz
