How do you change the default VLAN on an SG350?
mattybrownuk
On an SG300 switch, we use the commands:
vlan database
default-vlan vlan 11
exit
But the default-vlan command doesn't seem to be in the firmware on SG350 switches.  What's the equivalent command?  I can't find it in the web interface either.
balaji.bandi
as per my understating, default VLAN is the native VLAN,  Cisco switches (by default native VLAN 1)  you can change with native VLAN command (is this works for you ? or you looking for something different ?)
BB
Martin Aleksandrov
Have a look at this one and try doing it through the web GUI. https://video.cisco.com/video/6245245915001
