Bookmark
Subscribe
4650
how step by step enable ssh service in switch small bussines?
miroslaw.nowak
HI,
I upgraded Firmware on switch smallbussines 200, but I don't know how enable SSH.
Could somebody step by step how will do that?
9 Replies 9
Michael Gräber
how did you connect before the firmware update?
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf200e/administration_guide/OL-22849.pdf
As the document discribes use the ssh management key page to generate the key.
If there is a key already, delete it and generate a new one.
regards
miroslaw.nowak
I conected by web browser.
I think I have difrent switch...
I uploaded screenshot
Could you describe how do SSH?
regards
with SSH you can't connect by web browser, you can only connect to the cli.
If you want more security with your web browser enable https as shown in my first screen.
In your SSH configuration you set up an SSH user and password, is that the correct method you try to connect?
the more easiest way to connect is with an rsa public key, so server and client exchange the keys by themselves.
To do so, look at my second screen. Sry but i have only an sf302-08 for showing purposes, so i used your screen and marked the steps.
1. Delete the RSA und DSA key by marking them and klick on delete
2. Mark as user authentication "by RSA public key" and klick on apply
3. check the TCP/UDP services, SSH must be enabled manually (screen1)
4. reboot the switch
Now try to connect to the switch by putty or another ssh capable switch.
regards
I don't have SSH Service
Look screen please...
Is correct?
chrebert
Level 4
Level 4
The 200 series switches do not support CLI configuration.  If you want CLI, either through console, SSH, or telnet you would need an 300 series or higher.  For the 200 series your only option to configure the device is to use the web GUI.
There are some new switches coming out, the 220s that do support some CLI access, but your switch does not.
Hope that helps and thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
Thank you for full answer :)
Best Regards
miroslaw.nowak
Ok, I have switch 300
Could you please explain me how enable SSH, step by step or send me manual?
I added screen.
Best Regards
To enable SSH in the CLI simply type in ip ssh server.
To enable it through the web GUI, go to Security >> TCP/UDP Services and check the box for SSH.
Then simply connect to the switch's management IP using your preferred SSH client.
Hope that helps,
miroslaw.nowak
Yes, yes, yes, it works :)
Thank you. I don't know why I thought about SSH User Authentication etc., sorry
Best Regards
