07-28-2015 08:49 PM
Hi there,
I have three SG500X-24 all nicely connected with MGBSX1 nativily stacked switch1Master, switch2Backup, switch3Slave and fully operational with two VLANs I configured, one for my corporate network and the other one for the customer network (guest internet access). All done using the web GUI. The interface IP is 10.1.1.125 and it's on the same subnet of the corporate network 10.1.1.0 /24. Most ports on all three switches are being used for the two VLANs and their hosts, promiscuous ports etc..
However, I can only access the switches web GUI on the only ports I left untouched; these are ports 24 on each of the switches and those ports don't belong to any VLAN and they are left as trunk. Obviously my IT workstation is part of the corporate VLAN and need to access those switches using the web GUI and /or the CISCO Network Assistant software.
The VLAN config is as followed:
Interface IP 10.1.1.125. Interface Default VLAN ID1. (only port 24 in TRUNK mode belongs here)
Corporate VLAN Config:(I need this VLAN to access the switches please)
Primary VLAN 20 = promiscuous port 1, Secondary VLAN 21 (community VLAN 21)= port 3 - 21 private VLAN hosts. subnet 10.1.1.0 /24
Customer VLAN Config (to give them internet access)
Primary VLAN 30 = promiscuous port 2, Secondary VLAN 31 (community VLAN 31)= port 22-23 private VLAN hosts. subnet 172.16.0.0/24
I really appreciate your help.
07-29-2015 08:30 AM
So switch is not in L3 mode, right? In general you just need to have a default gateway set so 10.1.1.125 can route to wherever you need to manage it from.
Maybe share your config (remove passwords and public IPs) if you need more help?
07-30-2015 11:41 AM
Thanks for the rapid response. The switch is in both mode L2 and L3. However I'm only using it to handle the VLANs. all the routing is handled by my firewall. Port 1 and 2 of the switch are the promiscuous ports and connect to my firewall and that's the end of the line for the switch. I'm also including the running-config information
switchd24ff9#show running-config
config-file-header
switchd24ff9
v1.4.1.3 / R800_NIK_1_4_194_194
CLI v1.0
set system queues-mode 4
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 20-21,30-31
exit
interface range vlan 20,vlan30
private-vlan primary
exit
interface range vlan 21,vlan31
private-vlan community
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switchd24ff9
username
fdcdbc7d90e465e3512f7badc6c604fea74b034c privi
lege 15
username
c privilege 15
ip ssh server
snmp-server server
clock timezone " " 0 minutes 0
ip telnet server
interface vlan 1
ip address 10.1.33.125 255.255.255.0
no ip address dhcp
interface vlan 20
name Primary-VLAN20
private-vlan association add 21
interface vlan 21
name Community-VLAN21
interface vlan 30
name Primary-VLAN30-customer-wifi
private-vlan association add 31
interface vlan 31
name Community-VLAN31-cutomer-wifi
interface gigabitethernet1/1/1
switchport mode private-vlan promiscuous
switchport private-vlan mapping 20 add 21
interface gigabitethernet1/1/2
switchport private-vlan mapping 30 add 31
interface gigabitethernet1/1/3
switchport mode private-vlan host
switchport private-vlan host-association 20 21
interface gigabitethernet1/1/4
interface gigabitethernet1/1/5
interface gigabitethernet1/1/6
interface gigabitethernet1/1/7
interface gigabitethernet1/1/8
interface gigabitethernet1/1/9
interface gigabitethernet1/1/10
interface gigabitethernet1/1/11
interface gigabitethernet1/1/12
interface gigabitethernet1/1/13
interface gigabitethernet1/1/14
interface gigabitethernet1/1/15
interface gigabitethernet1/1/16
interface gigabitethernet1/1/17
interface gigabitethernet1/1/18
interface gigabitethernet1/1/19
interface gigabitethernet1/1/20
interface gigabitethernet1/1/21
interface gigabitethernet1/1/22
switchport private-vlan host-association 30 31
interface gigabitethernet1/1/23
interface gigabitethernet2/1/1
interface gigabitethernet2/1/2
interface gigabitethernet2/1/3
interface gigabitethernet2/1/4
interface gigabitethernet2/1/5
interface gigabitethernet2/1/6
interface gigabitethernet2/1/7
interface gigabitethernet2/1/8
interface gigabitethernet2/1/9
interface gigabitethernet2/1/10
interface gigabitethernet2/1/11
interface gigabitethernet2/1/12
interface gigabitethernet2/1/13
interface gigabitethernet2/1/14
interface gigabitethernet2/1/15
interface gigabitethernet2/1/16
interface gigabitethernet2/1/17
interface gigabitethernet2/1/18
interface gigabitethernet2/1/19
interface gigabitethernet2/1/20
interface gigabitethernet2/1/21
interface gigabitethernet2/1/22
interface gigabitethernet2/1/23
interface gigabitethernet3/1/1
interface gigabitethernet3/1/2
interface gigabitethernet3/1/3
interface gigabitethernet3/1/4
interface gigabitethernet3/1/5
interface gigabitethernet3/1/6
interface gigabitethernet3/1/7
interface gigabitethernet3/1/8
interface gigabitethernet3/1/9
interface gigabitethernet3/1/10
interface gigabitethernet3/1/11
interface gigabitethernet3/1/12
interface gigabitethernet3/1/13
interface gigabitethernet3/1/14
interface gigabitethernet3/1/15
interface gigabitethernet3/1/16
description IT_123
interface gigabitethernet3/1/17
interface gigabitethernet3/1/18
interface gigabitethernet3/1/19
interface gigabitethernet3/1/20
interface gigabitethernet3/1/21
interface gigabitethernet3/1/22
exit
ip route 10.1.33.0 /24 10.1.33.1
