how to add the IP address helper command to the switch
lornegallagher
I am trouble shooting a SF 200-48P and I am a bit lost without a CLI not used to the GUI. What I need to know is how to add the IP address helper command to the switch?
I have a number of IP phones which are not getting an IP address from DHCP (PCs which are diasy chained off the phones are all working correctly). On the higher end switches I would have added the IP address helper command to the VLAN and that would have sorted it. However I can't seem to figure out how to do this on the small business switch.
Lorne
rizwanr74
Level 7
Level 7
So your small business switch is trunk to your higher-end switch ?
On your higher-end switch vlan defined for VOIP has been configured for an IP-Helper address ?
thanks
Rizwan Rafeek
Thanks Rizwan. I was banging my head wishing they weren't small business switches as I felt lost without the command line!
Lorne Gallagher | McCann FitzGerald Solicitors | Riverside One, Sir John Rogerson's Quay, Dublin 2, Ireland | DDI +353 1 607 1726 | Fax +353 1 829 0010 | www.mccannfitzgerald.ie <>
Ireland Law Firm of the Year 2011 | Chambers Europe
Ireland Law Firm of the Year 2011 | International Financial Law Review
