How to connect SG 300- 28p Managed Switch by using (DB9 female to USB)
Hello!
I have a question " Is it possible to connect with (DB9 female to USB Serial) cable to SG-300 28p Managed Switch?
M Vithurshan
Sorry I was wrongly guiding you. You are right. If this switch have male connector and not RJ45 as usuall, then the cable you had show on the first print might be enough
You plug the DB9 to the switch and plug the USB  to your PC. You may need to install a driver on the PC. The driver usually comes with the cable but if not, you probably can find on the vendor side.
Hi @vithurshonvithu1234
 Cisco standard serial connector is RJ45 and not DB9 or USB.
hello sir!
In this case my Switch have console port as a RS232(Male) and my laptop Don't have ethernet port Sir. What i can do Sir?
I Should access with CLI.
I will have Attached Switch picture.WhatsApp Image 2023-07-13 at 13.56.38.jpgWhatsApp Image 2023-07-13 at 13.56.59.jpg
Hello Sir,
If I have this cable can I access?  that"s mean RJ45 will connect with Desktop or Laptop and another port will connect with My SG300-28p Managed Switch.
