Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 890 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5653 Views
  • 1 replies
  • 16 Helpful votes
We've encountered an unusual issue within our network configuration.Our core switch is an SG550X 24 Port 10Gb SFP+ Switch, and we are using SG350X switches for edge switching.When we configure Switch A and connect it directly to the core, everything ...
harrisfed by Level 1
  • 455 Views
  • 2 replies
I have 3x CBS350 switches set up in a stack. I configured the first switch from the console added a data vlan, IP address and added all the ports in to the data vlan. I then connected all 3 together and set up the stack using the web interface. Once ...
MikeEG by Level 1
  • 922 Views
  • 5 replies
I activated dhcp snooping on CBS 350 switch but nothing happened .I choose gi24 port as trusted port but nothing happened the switch still accept dhcp on the other ports.I want the optimum solution and the right syntax which activate dhcp snooping on...
ahmedaqsa by Level 1
  • 1308 Views
  • 7 replies
Hello,I have the following requirement,The Vmware colleagues specify a different Vlan for each host in a Nic. The Nic's of the Esxi hosts are connected to the Buisness Switches CBS350-24XS (Unit 1 + Unit 2, Stack).The Esxi hosts must be able to reach...
markusz by Level 1
  • 906 Views
  • 4 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
