How to create a static ARP using SNMP ?
Liok_3187
I want to create a static ARP using SNMP.
I can delete a ARP by setting oid '1.3.6.1.2.1.4.22.1.4' to '2' .
But neither of
      '1.3.6.1.2.1.4.22.1.1'
      '1.3.6.1.2.1.4.22.1.2'
      '1.3.6.1.2.1.4.22.1.3'
      can be modified or created
snmp-server community is RW
I can modify other oid, for example 'sysName' oid 1.3.6.1.2.1.1.5.0
I used this command to create a new ARP :
     snmp set v2 192.168.10.1 private oid 1.3.6.1.2.1.4.22.1.1 integer 1
the response:
     SNMP Response: reqid 16, errstat 11, erridx 1
      ipNetToMediaEntry.1 = 1
errstat 11 is NOCREATION
And I used the tool 'Mib Browser' to set a static a ARP,
the response is NOCREATION too.
I searched a lot of time, many people have this problem,
someone said the oid ipNetToPhysicalPhysAddress or inetCidrRouteTable is alternative,
but our switch haven't these oids.
I can't find a solution.
I want to know whether the task can be completed.
please help.
jeffrrod
Level 4
Level 4
Dear Fu,
Thank you for reaching the Small Business Support Community.
I am not positive this can be accomplished on the Small Business Switches, however, what is your switch model and firmware version so I can investigate further.
I'll be looking forward to your reply.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
jeffrrod
Level 4
Level 4
Dear Fu,
Kind regards,
Dear Jeffrey,
Thank you for your answer.
We talked with cisco support team.
Finally, their said that it is a bug and can't be resloved now.
anyway, thank you.
Regrads
