How To Set NetFlow Cisco SF200-24 using WEB UI
alifatic
is Cisco SF200-24 switch support netflow? if it's support netflow. how can i set it up through WEB UI, i have found on internet but it using command line. i'm new in setting up switch.
2 Accepted Solutions
 According to Cisco doc, it does not support Netflow but it does support Remote Monitoring (RMON) instead.
-If I helped you somehow, please, rate it as useful.-
Yes, it supports. Take a look on the link below:
https://www.cisco.com/c/en/us/products/collateral/switches/small-business-200-series-smart-switches/data_sheet_c78-634369.html
is this switch support snmp? can you show to me link cisco doc for this switch?
