Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2936 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4518 Views
  • 1 replies
  • 16 Helpful votes
Cisco really needs to do something about this since if you create a static bind using a MAC address the device generally doesn't receive the assigned IP but if you enter the client ID instead it will.  I don't know if the switch just doesn't check th...
viningele by Level 3
  • 3851 Views
  • 15 replies
hello experts,  i am not an expert on Cisco Switches, so i am using the web-gui to setup my switch. i have created an IP range for my network and also defined a different default VLAN - as i understand this to be 'best practice'. my default VLAN:199i...
Hello I have an Cisco SG-200-50 Switch and i have a problem with the LACP configuration. Actually I have an HP ProCurve 1800-24G Switch and here I configure LACP. On my PC (Windows 10) I have already activatet Teaming / LACP. All works fine. Th...
athlonk7 by Level 1
  • 752 Views
  • 2 replies
Hello, I have a Meraki router with a SG300 switch and 2 x WAP561 Access points on ports 47/48.  We currently have VLAN 1 (192.168.10.0/24) setup as our main network.  I have setup another VLAN for our guest network on our Meraki router, VLAN 50 (192...
ReidJones by Level 1
  • 826 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
