Idle Session Timeout not working on CBS250 series switches
Timo Kokkonen
It seems "Idle Session Timeout" doesn't work for HTTP/HTTPS connections on CBS250 series switches?
(example from a CBS250-24P-4X)
Updating value via web interface doesn't affect 'running-config', and user sessions get terminated after about 5 minutes regardless what the setting is set to (via web interface).
After setting HTTP/HTTPS session timeout to 30 minutes, and logging out and logging back in (and clicking "Port Management"), and leaving browser window 'idle':
23-Sep-2021 11:41:07 %AAA-I-CONNECT: New http connection for user admin, source 172.16.1.42 destination 172.16.1.10 ACCEPTED
23-Sep-2021 11:47:57 %AAA-I-DISCONNECT: http connection for user admin, source 172.16.1.42 destination 172.16.1.10 TERMINATED
switch1#sh ver
Active-image: flash://system/images/image_cbs250_ros_3.1.1.7_release_cisco_signed.bin
  Version: 3.1.1.7
  MD5 Digest: 4805a22186295e82609a0a3e6def88e0
  Date: 12-Aug-2021
  Time: 15:02:37
Inactive-image: flash://system/images/image_cbs250_ros_3.1.0.57_release_cisco_signed.bin
  Version: 3.1.0.57
  MD5 Digest: 9eac4c7725aaf03a8d8cfd1bf909edf3
  Date: 18-Jan-2021
  Time: 18:07:11
switch1#
Update:
Configuring timeout policy via CLI doesn't seem to have any effect either:
switch1#sh run | include ip http
ip http timeout-policy 0
switch1#
Still getting disconnected in about 5-10 minutes:
23-Sep-2021 12:27:11 %AAA-I-CONNECT: New http connection for user admin, source 172.16.1.42 destination 172.16.1.10 ACCEPTED
23-Sep-2021 12:34:58 %AAA-I-DISCONNECT: http connection for user admin, source 172.16.1.42 destination 172.16.1.10 TERMINATED
j.polisher
Got the same problem. Were you able to resolve it somehow?
Gateway MIS
Couple of years later and just got a new Business 250 switch, and I have the same issue.  I get logged out after only a few minutes even though it is set for 30 minutes.
Did you ever find a solution?
