IE 4010 Duel Power Configuration
PrimeGuy
  • Howdy,
We are currently operating this switch with 120V line to neutral. Per our proposed design we are planning on using 240V line to line. Would the switch operate correctly if we did switched over?
Another potential issue is our duel power supplies aren’t balanced. One is reading 240V, the other is reading 208V. Would this cause an issue an issue if both are connected to the switch.
 Check the device data sheet but as per my verification you are good.  The power supply was designed to work AC 100-240V/2.0A 50-60Hz considering PWR-RGD-AC-DC-H.  You may check if you device have a different power supply but the information does not change much
