Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3203 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4753 Views
  • 1 replies
  • 16 Helpful votes
Hi AllPlease help me, guys.I have configured the cisco business 350 series switch as below.My requirementVoice VLAN 10 and Data VLAN 20I need to carry both VLANs since I'm using a Laptop over an IP phoneSo used the CMD in all switch ports "switchport...
helloi am trying to set up 9 vlans with 123 (1UP) being the default. 120, 121,122 and so on. i tried to change the port to vlan to one of these and it seemed to work for a while but then the system got very slow. my port 52 shows all of my vlans in t...
I was setting up my network anew, I had just finished wiping the RV320 and sanitizing it.I loaded the wrong certificate from my computer and and now completely locked out of the GUI It's still passing traffic, but I have no way of logging in to chang...
Crazier by Level 1
  • 3317 Views
  • 12 replies
All of a sudden I'm having trouble logging into my SG350X running firmware 2.5.9.13.  This has happened before and usually it was a high CPU usage issue and a reboot would fix it but not this time. I see some other posts on this and even though they ...
tato386 by Level 6
  • 980 Views
  • 9 replies
Resolved! CBS350 capacity
Hello, I will setup a small network with 176 devices connected to the IP backbone. I want to use the CBS350 as an aggregation switch connected to 8 CBS220 switches in fiber 1G. Do you know if the CBS350 can handle 176 clients ? If yes, how many clien...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
