IEEE 802.3ad Connection Issues
mikew654321
I recently purchased a cisco 300 series 10 port managed switch and a synology 1511+ diskstation.  When trying to bond the 2 ethenet ports into link aggregation mode on the diskstation, i am recieveing an error that's "failing to establish IEEE 802.3ad connection".
From what i understand, the switch should allow this by defealt, but i am unable to determine why it's not allowing it.
If anyone could please help, it would be greatly apprechiated.  I am rather new to cisco gear.
Thanks!
Michael
derricklim66
Have you solved your problem?
I have the same issues with you except I'm using SG200-18 with Synology 1512+.
Tom Watts
Hello Mike Watts, can you provide the LAG configuration you've placed on the switch?
A lot of times the NAS will only support a LACP (not static LAG). However, if you can provide what kind of LAG the NAS will support will be most helpful.
From the command line here would be a sample input using LACP;
configure terminal
interface range fastethernet 3-4
channel-group 1 mode auto
From the command line here would be a sample input without using LACP;
configure terminal
channel-group 1 mode on
This will make a lag for port 3 and 4.
Please let me know if this helps at all.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
