I am experiencing problem with the following
I have used this software
show version
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
then upgraded to taken from other switch
c2960-lanbasek9-mz.122-50.SE1.bin
after reload i have experienced the following error
%ILET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization. This product may contain software that was copied in violation of Cisco's license terms. If your use of this product is the cause of a support issue, Cisco may deny operation of the product, support under your warranty or under a Cisco technical support program such as Smartnet. Please contact Cisco's Technical Assistance Center for more information.
The switch has been powered down for 5 minutes on the software but it did not help.
Also changing the flash to the old one and back to new one did not fix the problem.
On both is now showing this message.
Please advise.
1. How to fix this issue if possible.
2. Is it just information only or will it cause any issues to switch functionality?
Many Thanks
Raf
