Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3691 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5376 Views
  • 1 replies
  • 16 Helpful votes
Have a question regarding the configuration of an SMB SG500-28P switch which we set up to be stacked with 4 other switches (all are SMB SG50028P). We preconfigured the switch before going and installing at the customer's site. When onsite we found it...
bcodeus by Level 1
  • 456 Views
  • 0 replies
For some reason this is just eluding me.  Using WAP371s attached to SG300 PoE swtiches we find that they become unstable after a few days in some situations (in others they never get flaky, it's very strange) and would like to use the Time Range opti...
Hi, I need help to configure the SG300-10P switch for the following:port 9 connect to router (10.0.1.1) to internetVlan 1 (default) 10.0.1.200: ports 1 - 4 & 10: use for PCs and IP phonesVlan 2: 10.0.2.1: port 5, port 6, use for printersVlan 3: 10.0....
NilCipher by Level 1
  • 908 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
