inter vlan issues and clients connected to SG300-10 cannot access internet and server localy
dkapadiya
         Below is my router config and SG300-10 config.
Clients connected to wireless AP (connected to int gi0/1) can access internet, can ping the server but cannot access the files on the server connected on SG300-10
Clients connected to Sg300-10 can ping the server but cannot access the files on it.
VOIP adapter connected to Vlan 4 (gi4) able to work ok, (phones connected to voip adapter can dial out and receive calls)
native vlan 10 trunk (gi10) connected to router int Gi0/2
router#sh run
Building configuration...
Current configuration : 2626 bytes
! Last configuration change at 00:44:47 UTC Tue Apr 23 2013
! NVRAM config last updated at 03:11:27 UTC Mon Apr 22 2013
version 15.2
service password-encryption
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 ************************.
no aaa new-model
no ipv6 cef
ip multicast-routing
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.5
ip dhcp excluded-address 20.0.0.1 20.0.0.5
ip dhcp pool WIRELESS
import all
network 20.0.0.0 255.255.255.0
dns-server 8.8.8.8
default-router 20.0.0.1
lease 0 2
ip dhcp pool SWITCH
import all
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 10.0.0.1 8.8.4.4
lease infinite
no ip domain lookup
ip cef
license udi pid CISCO2911/K9 sn FHK1433F0DF
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description isp
no ip dhcp client request tftp-server-address
ip address dhcp client-id GigabitEthernet0/0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description WIRELESS LAN
ip address 20.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
description SWITCH
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 isp ip
ip route 10.1.2.0 255.255.255.0 10.0.0.2
ip route 10.1.3.0 255.255.255.0 10.0.0.2
ip route 10.1.4.0 255.255.255.0 10.0.0.2
ip route 10.1.5.0 255.255.255.0 10.0.0.2
access-list 1 permit 10.0.0.0 0.0.255.255
access-list 1 permit 20.0.0.0 0.0.255.255
access-list 1 permit 10.1.0.0 0.0.255.255
control-plane
line con 0
password 7 **********
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 ***************
login
transport input all
scheduler allocate 20000 1000
end
SG300-10 config
v1.3.0.59 / R750_NIK_1_3_647_260
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2-5,10
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp excluded-address 10.1.2.1 10.1.2.1
ip dhcp excluded-address 10.1.3.1 10.1.3.1
ip dhcp excluded-address 10.1.4.1 10.1.4.1
ip dhcp excluded-address 10.1.5.1 10.1.5.1
ip dhcp pool network D1
address low 10.1.3.1 high 10.1.3.254 255.255.255.0
default-router 10.1.3.1
exit
ip dhcp pool network D5
address low 10.1.2.1 high 10.1.2.254 255.255.255.0
default-router 10.1.2.1
exit
ip dhcp pool network SERVER
address low 10.1.5.1 high 10.1.5.254 255.255.255.0
default-router 10.1.5.1
exit
ip dhcp pool network VOIP
address low 10.1.4.1 high 10.1.4.254 255.255.255.0
default-router 10.1.4.1
exit
bonjour interface range vlan 1
hostname SWITCH
username cisco password encrypted **********
prevelege 15
no ip domain lookup
ip telnet server
interface vlan 1
no ip address dhcp
no ipv6 address autoconfig
no ipv6 enable
no ipv6 dhcp client stateless
interface vlan 2
ip address 10.1.2.1 255.255.255.0
interface vlan 3
ip address 10.1.3.1 255.255.255.0
interface vlan 4
ip address 10.1.4.1 255.255.255.0
interface vlan 5
ip address 10.1.5.1 255.255.255.0
interface vlan 10
ip address 10.0.0.2 255.255.255.0
interface gigabitethernet1
switchport mode access
switchport access vlan 2
interface gigabitethernet2
spanning-tree portfast
interface gigabitethernet3
switchport access vlan 3
interface gigabitethernet4
switchport access vlan 4
interface gigabitethernet5
switchport access vlan 5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet10
switchport trunk native vlan 10
exit
ip default-gateway 10.0.0.1
6 Replies 6
Tom Watts
Hi DKA,  can you make a diagram with port labels where everything is connected?
Can you also run the command on the Sg300  -  show spanning-tree
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Router
int Gi0/0 connected to ISP modem
Int Gi0/1 conneted to Wireless Access point
int Gi0/2 connected to Sg300-10 (int gi10)
SG300-10 Switch
gi10  to cisco router int gi0/2
gi6 to gi8 to pc's
gi5 to server
gi2 to gi3 pc
gi4  to Voip adapter (spa2100)
Spanning tree enabled mode RSTP
Default port cost method:  long
  Root ID    Priority    32768
             Address     84:78:ac:a5:e9:0e
             This switch is the root
             Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
  Number of topology changes 0 last change occurred 00:08:23 ago
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
Interfaces
  Name     State   Prio.Nbr    Cost    Sts   Role PortFast       Type
   gi1    enabled   128.49   2000000   Dsbl  Dsbl    No            -
   gi2    enabled   128.50    20000    Frw   Desg   Yes       P2P (RSTP)
   gi3    enabled   128.51   2000000   Dsbl  Dsbl    No            -
   gi4    enabled   128.52   2000000   Frw   Desg   Yes      Shared (RSTP)
   gi5    enabled   128.53    20000    Frw   Desg   Yes       P2P (RSTP)
   gi6    enabled   128.54   2000000   Dsbl  Dsbl    No            -
   gi7    enabled   128.55   2000000   Dsbl  Dsbl    No            -
   gi8    enabled   128.56   2000000   Dsbl  Dsbl    No            -
   gi9    enabled   128.57   2000000   Dsbl  Dsbl    No            -
  gi10    enabled   128.58    20000    Frw   Desg   Yes       P2P (RSTP)
   Po1    enabled  128.1000   20000    Dsbl  Dsbl    No            -
   Po2    enabled  128.1001   20000    Dsbl  Dsbl    No            -
   Po3    enabled  128.1002   20000    Dsbl  Dsbl    No            -
   Po4    enabled  128.1003   20000    Dsbl  Dsbl    No            -
   Po5    enabled  128.1004   20000    Dsbl  Dsbl    No            -
   Po6    enabled  128.1005   20000    Dsbl  Dsbl    No            -
   Po7    enabled  128.1006   20000    Dsbl  Dsbl    No            -
   Po8    enabled  128.1007   20000    Dsbl  Dsbl    No            -
The sg300 is in layer 3, are the default gateways of all connecting devices the gateway of the SVI?
Example a server connecting to vlan 5 default gateway of the server should be 10.1.5.1
-Tom
Yes the respective have thier own default router
10.1.2.1   Vlan 2
10.1.3.1    Vlan 3
10.1.4.1  Vlan 4
10.1.5.1  Vlan 5
exit
exit
exit
Part of this problem is, port fast should not be enabled on a port connecting to other device, this can make a network loop.
I don't see a dot1q encapsulation on the router config which also means I don't see an ip route pointing back to the switch SVI.
-Tom
Hello Tom this my basic setup
SG300-10 I want to use it in Layer 3.
Vlans 2, 3 and 4 do not need to communicate to the server.
All pc in Vlan 5 must be able to access the server also the PC's connected via wireless access must be able to access the server.
I would be using DHCP pool for wireless access point
I would be using DHCP pool on the switch for respective vlans.
Do I need to config the interface on router pointing to switch interface as router on stick, even though I am using the switch in layer 3 mode.
Please help me in config for the set up.
