Inter-VLAN routing issue
tomislavtomasic
I have 2 SG300 and 1 SG500 switch.
I am trying to setup inter-VLAN routing and DHCP relay.
They are connected thusly:
switch1[port49]<->[port7]switch2[port48]<->[port49]switch3
On switch1 I have set up VLAN3 with subnet 172.16.3.0/24 and on switch3 I have VLAN2 with subnet 192.168.1.0/24.
I need these VLANs to be able to communicate between each other.
I can ping from APC connected to switch1 to VLAN2 and VLAN3 IPs on switch2, but I cannot ping to those VLANs on switch2 from a PC connected to switch3.
Also, when I connect to managment interface on switch3 I cannot ping VLAN2 and VLAN3 interface IPs on switch2.
Traffic on default VLAN1 is passing through, though.
I tried changing the cable that connects switch 2 and switch3, but it didn't help.
What could be the issue here?
kcnajaf
Level 7
Level 7
Hi Tom,
Could you please provide the output of "switchport interface trunk" and "show cdp nei".
Najaf
Please rate when applicable or helpful !!!
Hi my friends,
         I also suffer same problem.  I have SF300 two switches.
SW1  Gi4 to SW2 Gi4:  (This for redundancy only)
I configure all vlans and ip address to it in SW1, i configure router as dhcp server with different 5 pools.  Only Pool which i working is from default vlan1 and other vlans not taking ip address from dhcp server and thier is no ping in between vlan (intervlan routing issue also.
Attached my SW2 configuration.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.02.18 19:31:07 =~=~=~=~=~=~=~=~=~=~=~=
sh r
SW2(config)#$                                                 sh run
% Unrecognized command
SW2(config)#do sh run
config-file-header
SW2
v1.2.7.76 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2-7
exit
voice vlan id 5
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
More: ,  Quit: q or CTRL+Z, One line:
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 10.1.6.252
ip dhcp relay enable
ip dhcp information option
bonjour interface range vlan 1
hostname SW2
interface vlan 1
no ip address dhcp
interface vlan 2
name " VLAN_2"
ip address 10.1.2.1 255.255.255.0
interface vlan 3
name "VLAN_3"
ip address 10.1.3.1 255.255.255.0
interface vlan 4
name "VLAN_4"
ip address 10.1.4.1 255.255.255.0
interface vlan 5
name "IP Telephony VLAN"
ip address 10.1.5.1 255.255.255.0
interface vlan 6
name "Switches VLAN"
ip address 10.1.6.1 255.255.255.0
interface vlan 7
name "Master VLAN"
ip address 10.1.7.1 255.255.255.0
interface fastethernet1
switchport mode access
interface fastethernet2
interface fastethernet3
interface fastethernet4
interface fastethernet5
interface fastethernet6
interface fastethernet7
interface fastethernet8
interface fastethernet9
switchport access vlan 2
interface fastethernet10
interface fastethernet11
interface fastethernet12
interface fastethernet13
interface fastethernet14
switchport access vlan 3
interface fastethernet15
interface fastethernet16
interface fastethernet17
interface fastethernet18
switchport access vlan 4
interface fastethernet19
interface fastethernet20
interface fastethernet21
interface fastethernet22
interface fastethernet23
interface fastethernet24
interface fastethernet25
interface fastethernet26
interface fastethernet27
interface fastethernet28
switchport access vlan 5
interface fastethernet29
interface fastethernet30
interface fastethernet31
interface fastethernet32
interface fastethernet33
interface fastethernet34
interface fastethernet35
interface fastethernet36
interface fastethernet37
interface fastethernet38
interface fastethernet39
interface fastethernet40
interface fastethernet41
interface fastethernet42
interface fastethernet43
interface fastethernet44
interface fastethernet45
interface fastethernet46
interface fastethernet47
switchport access vlan 7
interface fastethernet48
switchport access vlan 6
interface gigabitethernet4
switchport trunk allowed vlan add 2-7
Description Connection To SW1
SW2(config)#
Hello Tom,
Kindly ensure atleast One physical port is part of the VLAN and Active (it must be up on at least one port).
Thanks and regards,
Siva
