Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3053 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4628 Views
  • 1 replies
  • 16 Helpful votes
Hi,I am working on a SF 300 . I favor the cli over the web-interface. I will like to make a private-vlan community but do not know if my sequence of commands are right or allowed.Can someone point me in the right direction please ?MedSwitch#configure...
We have been deploying Cisco SF200-24P switches for our systems for over a year now. They connect to a Cisco 881 router. In many cases we are also deploying Cisco AP541s.Over the last few months, on an intermittent basis, the switches will simply fre...
Hi,I have a 302-08Mp attached to my network, it is plugged directly into a C3560G, however when i plug a phone into this switch i get a 'configuring ip' message up on the phone. The voice vlan is set identical to the 3560 but in the logs i get an err...
Good Afternoon AllI have a 24port SGE2000P and a 48 port SGE2010.My SGE2000P works brilliantly.However my SGE2010 is very poorly.  When turned on all the port lights are on for some time.  Then they extinguish very briefly and a stack light comes on ...
Hi!The switch SG500X-48 has 4 SFP+ ( 10G ) ports - XG1, XG2, XG3/S1, XG4/S2 - and two configuration modes - standalone and "native stacking". Can I use XG1 and XG2 SFP+ ports to connect servers when "Native stacking" mode is active ? Thanks,Leonardo...
ltobal by Level 1
  • 1552 Views
  • 1 replies
Hello,New in a company that have 2 SG200-26, The system administrator left without giving any password.Is there a way to reset the password, I can't find something that applies on thos switches.The best would be to reset the password without reseting...
emonge4242 by Level 1
  • 48465 Views
  • 8 replies
                   I changed the setting from static to dynamic and the switch froze up. all lights on the panel flashed, when they stopped the system light on the left side continued to flash. I tryied unplugging unit as well as depressing the reset...
mako4146 by Level 1
  • 8248 Views
  • 8 replies
My setupCisco 2811 ISRLinksys SFE2000PCisco 7940 IP PhoneI have created 3 VLANs for this setupVLAN 2 - VoiceVLAN 3 - DataVLAN 10 - ManagementThe Cisco 2811 ISR connects to the SFE2000P via the FA0/0 port. Subinterface has been created on the cisco ro...
Hi EveryoneI need some help.On my cisco switch/router i have created 4 vlans, using the below interfaces192.168.1.254 if the ip address of the switchport 1 which is vlan1 is connected to my Netgear WDNR4500 Wirelss RouterThe remain ports are connecte...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
