IP Based ACL on switch
timjeens1
Hey everyone,
I need some help setting up IP based ACLs for voip phones on my Cisco switch (SGE2010p).
Basically I have no idea what to put in the window (see attached image)
What protocols?  What IP addresses? what ports?  do I need to put the DSCP number here or elsewhere?
-Tim
7 Replies 7
jasbryan
Level 6
Level 6
Tim,
Are you trying to set up QoS for your VOIP phones? or just ACL's? If so explain what you are trying to accomplish.
Jasbryan
Hi Jas,
Yea I'm trying to QOS for my VOIP softphones.  No idea how to set it up, and thought I would have to use ACL's, but if you know a better way that would be good, basically I have no idea how to do it.
Why: all of our phones within our network are getting choppy sounds, for hard phones and softphones.  we are using xlite (softphones), and Ploycom SoundPoints (hard phones, these do not support DSCP)
we currently have 4 of these switches in a stack, and notice drop out of everything if a large transfer is made between a server and workstation.  we are going to move this to a LAG layout, but would like to get QoS set up as well.
So if you can help that would be great.
If you need more info then just ask
-Tim
Tim,
if you are trying to set up QoS you will need to create one ACL to mark your interesting traffic. I will try and type up a how to document and post shortly.What subnet is your VoIP traffic on?
Jasbryan
Brilliant Thank you.
/23 is our subnet.
-Tim
Tim
what is your IP address scheme for VoIP?
Jasbryan
They are given out via DHCP
10.20.30.***
-Tim
Step 1
Add IP Based ACL
ACL Name = VoIP Qos
Rule priority 10
Protocol = ANY
Source Port = ANY
Destination Port = Any
TCP Flags = don’t set leave default
ICMP = don’t set leave default
ICMP Code =don’t set leave default
IGMP = don’t set leave default
Source IP Address =10.20.30.0 0.0.0.255
Destination IP Address = ANY
Traffic Class = don’t check
Action = permit
Now we need to add another rule to permit all under ACL we just create , click close and now click add Rule
ACL Name = VoIP Qos
Rule priority 20
Protocol = ANY
Source Port = ANY
Source IP Address = ANY
Action = permit
Step 2
Make sure the SGE switch QoS is in Advance mode
Quality of Service••àGeneral••àCos ••àQoS mode = Advanced
Step 3
Under Advanced Mode
Class Mapping
Class Map Name = CMVOIP
Check IP ACL ••àcheck IPv4 (ACL NAME you created)
Apply
NEXT add a policy
Policy Table
New Policy Nam= VoipQos
Check Class Map and choose Class map we just create
Check Action     set DSCP new Value = 46 ( This value can be what you want it to be)
You can leave police unchecked
And apply settings
Now add the policy to the ports
This should include Advance QoS setup
Hope this helps,
Jasbryan
