Is there a way to gather data of Optical Module Status through SNMP?
mema7261
When using the snmpwalk command to query a Cisco SF302-08PP switch with the -c public community string, am not able to find data related to Optical Module Status and CPU Utilization. I am trying to collect the data of a switch through snmp protocol using the following command:
snmpwalk -v2c -c public IP_ADDRESS_CONNECTED_SWITCH
Is there a recommended solution or alternative approach to successfully retrieve data on Optical Module Status and CPU Utilization through SNMP for this particular switch model?
Mark Elsen
 - You may try to have an (snmp) walk through the https://mibs.observium.org/mib/ENTITY-SENSOR-MIB/   but I doubt the small business types of devices offer support for it ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
There may be some Limitaton you may not get all what  you looking
check the OID available - check is there any MIB you can download from download site.
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-smart-switches/smb5512-cisco-small-business-switches-model-object-identifiers-oids.html
Also good to read below thread :
https://community.cisco.com/t5/network-management/cisco-sf300-24-searching-oids/td-p/1972982
BB
