Cisco SF500 problems
ReeQ
Hello everyone,
trying to connect to switch via console.
The switch has a DB9 socket as a console, I connect the serial cable to the PC via a USB adapter. In the PUTTY application, I select the appropriate COM3 port and the console is displayed, but I cannot enter anything. I tried different port speeds. Can someone help me?
8 Replies 8
M02@rt37
Hello @ReeQ
Do you (re) install the USB adapter on your PC ? Is ot recognized ?
Best regards
I did not install drivers for the adapter, but the cable was detected in the device manager
Ok @ReeQ
Are you sure the original cisco console cable is used ?
Best regards
the cable is not original from cisco
i would suggest to get orginal cable or compatable one - we seen these kind of issues in the community (due to cable errors)
other option you can still configure using Web GUI as i have provided the document above post.
BB
balaji.bandi
Make sure the correct console cable used and check the below installation guide : (Use the console port)
on putty try always parity and flow control  - none
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/quick_start/en/500_Series_QSG_En.pdf
BB
Will any db9 cable fit? Does it have to be original Cisco?
Unfortunately, the switch already has configuration, but I don't have the password
