Hi there,
can some one tell me the exact size is it 9000bytes or a more common number which is exactly supported.
Abd be did I understood the command reference guide correctly that if a frame bigger than that will arrive the port will go shutdown? Will it create an error message wit the details?
cheers,
sebastian
