LAN Switching, SG350-10P 10-Port Gigabit PoE Managed Switch
I have connect Avaya 1608 to SG-350-10P but its not get communicating to the network. Its showing bad router.PC's are working fine
marce1000
 - Can you post screenshot ?
 M.
PFB
 - Ok but note that you have connected a switch only , not a router if the Avaya would expect that , as a result  the problem is more at the Avaya site , you may find these links informational :
            https://www.fixya.com/support/t26190291-whats_solution_bad_router_in_avaya_ip
            https://www.tek-tips.com/viewthread.cfm?qid=1781834
                                 and support site : https://support.avaya.com/
 M.
Can anyone share the graphical- Voice vlan configuration on the switch
