09-30-2020 06:04 AM
Good morning
I have in my office a small modem with 6 connection ports. I would like to connect a layer 3 switch in eat so that I can have 2 vlans one that can see the internet and one that will not be able to see the internet. Is this possible ? what switch tpe/model will you recommend ( SG350 ? ) . Thanks
Solved! Go to Solution.
09-30-2020 06:10 AM
if this is small business yes it should work. as per the description you provided.
09-30-2020 06:10 AM
09-30-2020 06:48 AM
