I was trying to upgrade the FW of SFE2000P from 1.0.0.48 to 1.0.1.1 via web based management but went in problem. Now all the ports are in green and there 's no activity, can't ping it via default ip. Connected with console cable, and this is the output with a infinite loop of this. Tried to send the original 1.0.0.48.ros firmware and the 1.0.1.1.ros also via xmodem console cable, no effect! What can be done?
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.0.05 Built Aug 27 2006 10:04:28
Networking device based on 88F5181L CPU with ARM926EJ-S core.
128MByte SDRAM. I-Cache 32 KB. D-Cache 32KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
FAIL !!! Check image for valid file.
Switching to the second image ...
100%
Both images are not valid ...
Please download a new image.
Downloading code using XMODEM
