Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2919 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4502 Views
  • 1 replies
  • 16 Helpful votes
Hello there, I have a problem with my switch as everytime I remotely reboot it I get it stuck and the sys light becomes orange. The only way I found to resolve this is by unplug it and plug it back again. Ios version is 15.0(2)EX5 Could use your advi...
Hi, I have purchased a CISCO SG-300 and downloaded the latest firmware for it which seems to be Sx300_FW_Boot_1.4.1.03.zip I unzipped the file and navigated to Upgrade/Backup Firmware and browsed to the location of the file and selected the file and ...
varouj by Level 1
  • 684 Views
  • 5 replies
I recently purchased the Cisco Compact 24-Port Gigabit Switch with 2 Combo Mini-GBIC Ports (SG102-24-NA) and I'm worried I purchased the wrong one switch for my business. My intention is to connect our Apple Airport Extreme to the Cisco switch in or...
Hi Everyone, I have two Vlan on SG300 Switch, One Vlan is for Server (VLAN 20) IP-(192.168.20.0)  and other is for clients (VLAN 50) IP-(192.168.50.0) When i'm trying to join a client to domain an error message is coming but when i change the ip addr...
STP
Sir, I have 30 nos Cisco SF300 Switch in my network. My network seperated by Core-Area-Distribution-Edge, & Every Vlan's Area is Root for the same. Now  I configured Vlans & STP (Given highest priority-61440) the new SF300 switches & placed as per re...
Has anyone ran across this issue before? This SF500-24 loses the entire config and it has to be restored from the back up, the person that originally set up these switches is currently unavailable and I am trying to help restore the config, apparentl...
kacyhicks by Level 1
  • 293 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
